oil dipstick no reading
Old Nov 26, 2010 | 05:32 PM
auerdoan's Avatar
i have a oil dipstick showing just a bit of oil on the end
i just replaced the oil pan seal and the seal needed for the windage plate
same seal.
i put 5 quarts in i dont have what i believe is the 7 inch
i have the other i believe is a 5
is the another available
does anyone know the lenght of a oil stick for a 5 inch pan
should the stick go in till it hits the bottom
than work my way up in some way
now for the dumb question
i put oil in the big hole on my valve cover ....just checking
its a new vehicle me
440 engine i think early 76
thanks for the help
Old Nov 27, 2010 | 05:04 AM
I believe that you need to add some more oil, maybe half a quart or so. If you have run the motor since filling it, the oil filter will hold .5qt itself.
Old Nov 27, 2010 | 08:47 AM
blue 68 gts's Avatar
Add 1/2 qt and re-check till it shows. It's like5 1/2 or 6qts for a 440 i believe. Mine takes almost 8 qts.
Old Nov 27, 2010 | 08:54 AM
Agree..... Add a half a quart and then re-check.. May need the other for the filter....
Old Nov 27, 2010 | 09:24 PM
auerdoan's Avatar
Thanks guys sound like im close.
i didnt want to overdo it.
what are the symptoms of having too much?
thanks again for your help.
Old Nov 27, 2010 | 10:00 PM
The oil will foam from the crank whipping it
Old Jan 4, 2011 | 12:22 PM
auerdoan's Avatar
I wanted to touch base.
Adding another 3/4 of a quart did the trick.
when i did the change i also replaced the pan gasket. When i did this i let it sit for a few days, I wanted to give the pan a new paint job.
Im thinking every last drop of oil could of dripped out causing it to need a bit more.
Thanks guys!!
mrzods13
Jun 9, 2014 06:27 PM
tjmr2
Sep 6, 2009 09:15 AM
craveman
Apr 17, 2009 02:42 PM
rammen99
Nov 11, 2008 01:18 AM
dzltd02
Oct 28, 2008 08:25 AM
