roller cam shaft
Old Jun 2, 2013 | 03:49 PM
goldenpistol's Avatar
roller cam shaft
Hi to all
what best roller cam shaft range for my new converter stall 2200 to 2800
Thanks in advance
Old Jun 2, 2013 | 04:16 PM
dartcuda's Avatar
roller cam shaft
Best advise. Go to a cam company and tell them what you are building.Give them all the info they ask for and they will tell you the best cam for your combo. Mark
Old Jun 2, 2013 | 07:53 PM
Gorts 5th's Avatar
is there a reason you are choosing a roller cam?
a solid or hydraulic will give you a longer hp rpm range than a roller cam.
maybe not as high hp but say a peak of 400 hp but the rpm rang 350 400 350
aver a total rpm range of say 2500 to 6000
roller hp 425 but with a total 350 425 350 over a rpm range of 3000 to 6000
you have a higher peak hp but the range is shorter a longer hp rpm range will pull harder longer than the roller with a shorter total rpm range
check this link out
https://moparforums.com/forums/f81/p...184/#post97548
Old Jun 3, 2013 | 08:03 AM
roller cam
Thanks gorts i am new in mopar so i need help building my 440 engine dtls
440 rb year 78 piston bore 40 flat tappet speed pro forged
edlbrock performer rpm daul plane square bore range 1500 -6500
with aluminum stealth cylinder from 440 source.com
rearend 8 1/4 with 3.55 ratio
converter boss hog 2200 to 2800
carp hly 850 hp altra light
now on the car 750 hly old carb and stock rocker stock cam stock pushrods
i want upgrade to voodoo lunati cam,lifters,timing chain,springs
need full kit what part number will fit my engine
need your help i already bought now prw roller rockers 1.6 ratio
Thanks in advance
moparjohnson123456
Jun 14, 2011 01:28 PM
timmie124
Aug 18, 2010 08:32 AM
norcalmopar
Aug 6, 2010 03:51 PM
autotyme
Mar 29, 2010 01:26 PM
Mopar_71
Jul 17, 2009 06:05 PM
