Stupid rotor cap question
Old Jan 7, 2011 | 12:15 AM
MagnumBlue's Avatar
Rollin' on dubs
I have a 78 magnum with a 318. I've changed many distributor caps and every one of them just popped right off. The cap on my magnum is either stuck, or attached. Looking at the new one I don't see where it would attach somehow.
Is there something I'm missing or is it just stuck?
Old Jan 7, 2011 | 07:47 AM
MrOldart2U's Avatar
I am assuming you have the clips unclipped? if so its just stuck, usually a bump with the heel of the hand will unstick it...
Old Jan 7, 2011 | 08:24 AM
1966sportfury's Avatar
A.K.A Bob Dodge
if you look off to the left of the wires is the clips that hold the cap on there are two of them.one on each side
Old Jan 7, 2011 | 08:49 AM
I've seen some caps that seemed to "shrink on." I assume it is a problem with either quality control, or a reaction due to heat. In this day and age of reduced quality control..........
Old Jan 7, 2011 | 01:11 PM
MagnumBlue's Avatar
Rollin' on dubs
Sorry, reading back I seemed to have worded my question wrong. The cap is off but I can't get the rotor off. Sorry for the confusion.
Is this just supposed to pop off, or is there somethng I'm missing?
Thanks again
~Matt
Old Jan 7, 2011 | 04:08 PM
samuelcosmo76's Avatar
ive heard of having to break the rotor off with pliers sometimes. correct me if im wrong...
Old Jan 7, 2011 | 10:54 PM
Thanks again
~Matt
Same problem with rotors, I assume they change with heat
Old Jan 8, 2011 | 03:11 AM
MagnumBlue's Avatar
Rollin' on dubs
Well, that may be the case because I cracked it trying to pry it off and I don't see any fasteners that keep it on. It looks really old.
Old Jan 10, 2011 | 01:45 PM
badsport's Avatar
45 years of Mopars
No fasteners, it's just stuck.
crwchf16
Feb 29, 2012 01:45 PM
rcknrolfender79
Feb 24, 2011 12:03 PM
rcknrolfender79
Nov 8, 2010 08:35 PM
Rex 360
Dec 12, 2009 08:02 PM
rammen99
Nov 11, 2008 01:18 AM
