Are these the right sealants??
Old Jul 3, 2021 | 05:40 PM
KX5's Avatar
KX5
Hey everyone, not sure this is the right forum but here it goes.
I'm replacing the rear main seal on my 2005 Jeep 4.0L In the service manual i have it says to use "Mopar Gasket Maker Sealer" on the bearing cap and "Mopar Silicone Rubber Adhesive Sealant" on the block and pan gaskets in certain areas. Then in a tutorial online it says to use "LockTite 518" which is an Anaerobic sealant on the bearing cap. They say this is called out for specifically in the service manual and you have to use this. Then High Temp RTV on the pan gasket. Well, I went to jeep to get the parts and just got the sealants at the same time to save a trip to somewhere else, and this is what they gave me. They told me this is what i needed and sent me on my way. They all but look the same to me, so i don't know which one to use in each spot or if they are even right.
Can anyone let me know if these are right and if so which one i need to use where.
Thanks
Old Jul 4, 2021 | 08:26 AM
44B should be the Black Silicone
44D Should be the Gray Silicone
If i and not mistaken the 44D is suppose to be the same as the Permatex 518 Gasket Eliminator.
The way 518 works is, When you mate the surfaces and take the air away from the two sealed parts, the compound hardens. The sealant is good up to 0.015 gap sealing if I recall.
SO to me :
44B for the pan
44D for you rear main Retainer / seal
Old Jul 4, 2021 | 10:05 AM
also, those are just suggestions lol. any sealant of the correct variety from any brand will work. of course they are gonna try to sell some mopar stuff but it's far from necessary.
Old Jul 5, 2021 | 07:57 AM
KX5's Avatar
KX5
SO to me :
44B for the pan
Thanks for this. I looked online and couldn't find anything about either one and wan't sure which one to use where. thanks again!!
Yeah i get that, i was just in there getting other stuff so to save me a trip elsewhere i got it from them... then the markings didn't say one way or another so i was confused on which to use. lol..
RBLowbucks
Jan 16, 2019 09:39 PM
fivepoint
Aug 27, 2017 04:34 PM
raycan2
Aug 5, 2013 05:22 PM
Mr. Belvedere II
Jun 21, 2012 08:50 AM
brasschuckles
Oct 15, 2007 11:35 AM
