Wiring in new distributor
Old Apr 17, 2017 | 11:04 AM
70newport's Avatar
So I am finally getting around to installing my new electronic ignition conversion distributor with the mopar ecu. I am having a struggle with the wiring and the guys at mancini are having trouble with it too.
My starter relay only has 4 posts not the 5 like the ones in the instructions. The one side for ignition goes to the "In" on the resistor and ties to the Blue/yellow wire from the ECU. where does the other side of the resistor go? just to "+" on the coil? or does it go to there and to the middle "start" post on my relay also?
my relay is this one. http://i.ebayimg.com/00/s/Mzc1WDUwMA==/z/nP8AAOxycD9TVl3W/$_3.JPG?set_id=2
Thanks,
Gary
Old Apr 17, 2017 | 05:46 PM
This Should Answer your question...
http://www.crazysmopar.com/tech/ecu/ecu1_sm.jpg
https://www.searchlock.com/search?sa...par+ECU+wiring
http://www.crazysmopar.com/tech_ecu.html
The kit did come (Or you have the resistor) Rite?
Old Apr 17, 2017 | 07:31 PM
70newport's Avatar
so I tried wiring according to this after I posted actually and when I wired it like this with the yellow from the relay going to resistor out and + on cool the car cranks as soon as I turn the key to on, not start. I disconnected the yellow and just left the resistor tied to + and it seems to work. Is there an issue leaving it this way?
Thanks.
Old Apr 18, 2017 | 05:59 PM
Should be... Just means you might not get a full 12 Volts when you are in the cranking position... But should be ok...
Old Aug 16, 2017 | 09:39 AM
Bigmark's Avatar
I have a 67 Dodge Coronet with a 383 and points distributor. I'm converting it to Chrysler electronic distributor with Chrysler ECU. I seem to recall reading somewhere that you need to change the alternator and voltage regulator to a newer style like 72/73 that came with electronic ignition. Is this correct?
Old Aug 22, 2017 | 10:33 PM
moparted's Avatar
no
Packard526
Sep 15, 2014 09:08 PM
Colorado_Fury
Dec 31, 2013 09:53 AM
peterlucas
May 16, 2013 11:08 AM
70Coronet
May 7, 2012 06:48 AM
Aspen
Aug 31, 2009 10:25 PM
