1972 Duster has trouble idling
Old Aug 22, 2017 | 07:35 PM
Duster_Dude's Avatar
Hello,
My 1972 Plymouth Duster has a 225 cubic inch slant 6 and It's having trouble idling. The engine will run fine except when its going slower than 15 miles an hour on the road or when it comes to a stop. At this point, I have to throw it in neutral and keep hitting the gas pedal so that it doesn't quit running. I know there's a small vacuum leak somewhere that makes a load whistle sometimes but Its never caused this type of problem until now. Could this be the cause of a major vacuum leak? perhaps the carburetor is just getting to old?
Thanks,
Old Aug 22, 2017 | 07:41 PM
Could also be a bad hose ????
Or a vacuum plug fell off???
Old Aug 22, 2017 | 07:45 PM
fivepoint's Avatar
The vacuum leak would be the first thing to repair. You may have more than one leak now.
Old Aug 22, 2017 | 07:52 PM
Archer's Avatar
DD -
Vacuum leak (big or small), or fuel metering problem (carb).
Old Aug 22, 2017 | 07:54 PM
The engine has a small one barrel carburetor with 3 hoses of which I have replaced two of them. I don't see anything wrong with the 3rd hose with the naked eye. How do I go about testing to see if there is a vacuum leak somewhere?
Old Aug 23, 2017 | 05:33 PM
fivepoint's Avatar
Don't forget to check for a leaking power brake vacuum hose or the brake booster itself. You can check for other leaks around the carb base or intake mounting by carefully spraying ether around them. The RPM will change if there is a leak. I have heard WD40 will work too.
Old Aug 23, 2017 | 07:09 PM
Archer's Avatar
DD -
Spray the running engine. including gasket areas and both ends of vacuum lines with a soapy water solution and listen for a change in rpm/sound.
t65fury3
Dec 22, 2016 08:48 PM
josehf34
Aug 18, 2014 02:21 PM
josehf34
22
Dec 25, 2013 01:37 PM
theFUSELAGE KING
Feb 17, 2012 03:42 PM
bushwood
Aug 2, 2011 05:40 PM
