1973 Challenger Engine Leak Question
Old Sep 8, 2020 | 11:29 AM
Sean Smiley's Avatar
Hello. I am restoring a 1973 Dodge Challenger, 340 4 barrel, with my teenage daughter, and we just got the engine to turn over after replacing-oil, oil filter, spark plugs, spark plug wires, ignition system, fuel filter, fuel pump. While we were doing our happy dance, the engine started to spew coolant from a hole near or on the engine block, between the belts and the main block.
Photos of it on this are attached. Red circle indicates where hole with leaking coolant is located.
My question is: Can someone verify from the photos/image that this is in fact a hole in the upper part of the engine block, and that our project is now over? Or is this a part of the engine that can be replaced while keeping the same serial number engine block?
Thank you in advance!
Old Sep 8, 2020 | 01:43 PM
You need to replace the Timing Cover....
Good little project... Keep chipping at it....
https://www.jegs.com/i/JEGS+Performa...SABEgL3xvD_BwE
Old Sep 8, 2020 | 01:51 PM
Thank you RacerHog!!
Do you recommend a particular company to buy the Timing Cover replacement from? YearOne has one, but it is $200. JEGS has one that is only $74.83. AutoZone for $99.
Old Sep 8, 2020 | 05:29 PM
fivepoint's Avatar
Mancini Racing has a timing cover/ water pump kit that includes all of the gaskets for 145.00 they also have a kit with high volume pump for a few bucks more.
Old Sep 9, 2020 | 07:17 AM
Thank you sir. I will check them out.
Old Sep 9, 2020 | 02:56 PM
No preference here.... Check with your local parts store also... My be able to get it for you in Dorman Products also...
Going to need Cover / Seal / Gaskets... Good Luck..
Diz2050
Apr 25, 2020 02:42 AM
Casey.Greb
Dec 11, 2019 09:31 AM
rcknrolfender79
Feb 19, 2018 11:08 AM
Oldsmobileman
Apr 11, 2010 05:49 PM
parkinsonsfight
Mar 1, 2009 02:43 AM
