318 to 440 swap
Old Aug 31, 2013 | 12:16 PM
  #31
slade's Avatar
now im confused haha
Old Aug 31, 2013 | 12:52 PM
  #32
Originally Posted by Chromey
I marked it as coil so it must go to coil from 318 motor. I assume it would be same on 440
Yes to coil +..... Hot with Key On....
Old Sep 1, 2013 | 05:39 PM
  #33
Chromey's Avatar
Ok I had a great day. Got the 440 running and car moves under own power. I have one problem though. It starts just fine and runs great at high idle. It also runs good with throttle. But when it's at low idle it will die. If u try starting it with throttle slightly depressed it will pop through the carb.
the screw in front drivers side was missing and i put one in off a spare carb i had but dont know what the setting needs to be. i am talking about the screw that have two of them one on each side for primary( name is slipping my mind)
What is my first step to diagnosing the problem. I am pretty sure all vacuum lines are plugged but I have not removed any of them. Any help would be appreciated.
  #34
Chromey's Avatar
What is initial setting for all the adjustment screws for the carb also
Old Sep 1, 2013 | 06:24 PM
  #35
Out 2-3 turns.....
Old Sep 1, 2013 | 07:20 PM
  #36
Chromey...You can see the Idle adjusting screw on page 5 of my photobucket down in my sign.
Old Sep 1, 2013 | 08:04 PM
  #37
.....Almost there.....
Old Sep 6, 2013 | 07:54 PM
  #38
Sorry Pm box is full......Hahahahahahaha
Yes Different setting for sure....
Fix the one that fits the 440.... Thats the best bet....
Old Sep 6, 2013 | 07:56 PM
  #39
Chromey's Avatar
Ok thanks. Smacking my head on why someone would put that carb on that motor? Very confused
Old Sep 6, 2013 | 08:03 PM
  #40
Looks to me, from what I have resource for.... The....
9097 carb fits the 1976 400 Ci
9023 carb fits the 1974 440 Ci
Dont forget after you get it all cleaned out..... Blow out the fuel line and get any crap out of it that might have gotten past the filter.....
Old Sep 6, 2013 | 08:20 PM
  #41
Chromey's Avatar
Yep thanks
Old Sep 6, 2013 | 08:26 PM
  #42
No...Problem....
ocdmoparworker
Oct 4, 2010 04:01 PM
chlngr1970
Sep 30, 2010 08:54 AM
dusterboy89
May 21, 2010 10:48 PM
dustin2100
May 12, 2010 03:35 PM
dobaon22s
Nov 5, 2008 01:42 AM
