440 cast crank replacement
Old Nov 2, 2017 | 01:23 AM
Terry Howder Jr's Avatar
hi im new to this forum so sorry if this has been ask before. I would like to know if i buy a 440 that has a cast crank can i buy a steel crank to replace it?
Old Nov 3, 2017 | 04:40 PM
Having broke a cast crank in a 360 I would go forged for the extra insurance and ability to up grade Nitrous or turbo
Old Nov 15, 2017 | 04:55 PM
hjc's Avatar
hjc
You should be able to replace the cast crank with a steel crank; however most cast cranks are externally balanced and most steel cranks are internally balanced. This means you will have to replace the harmonic balancer and the flexplate /torque converter. This assembly would need to be rebalanced. The other option would be to balance the steel crank externally and use the harmonic balancer and flexplate/torque converter you have. you might have to replace the plate that attaches the torque converter to the crank.
hjc
Terry Howder Jr
Nov 2, 2017 06:27 PM
dpmalibu
Jan 21, 2013 11:12 AM
HonkyCat
Nov 26, 2012 07:54 AM
Minnesota Guy
Oct 21, 2010 10:41 AM
atowncris
Nov 19, 2009 12:48 PM
