440 MPG
Old Mar 17, 2019 | 07:41 AM
Apewalski70's Avatar
440 MPG
Hello everyone.
What do you think about my 440 fuel consumption, here the engine specs (I give you all) :
1973 440, stock head cylinders, probably low comp pistons, MSD 6AL, blaster 2 coil, stainless exhaust, Holley Sniper EFI injection, Holley Dual Sync distributor (36 à WOT), Edelbrock Torker II intake.
Comp Cams camshaft : duration 284 intake, 296 exhaust. @ .050" lift : 240 int, 246 exh. valve lift : 0.507 int, 0.51 exh.
8 3/4 axle, I think I have a 3.93 gear, I'm not sure about the gear because the factory tachometer is not really accurate.
Tires : P235/60/R15
I run with E85, so I up the fuel around 30%, with i've done a 4.8 MPG, just short travels, no highway, something like 7/10 mileswithout being really kind with the weight of my right foot.
. With basical gasoline I would be around the 6,8 MPG.
Is that seems right to you ?
Old Mar 17, 2019 | 08:20 AM
Your rt foot has a lot to do with fuel mileage but 8 to 10 is what I would be looking for with your combination. One thing with the low compression e85 is less that ideal, 12 to 13.5 to 1 cr would be more efficient.
Old Mar 17, 2019 | 09:04 AM
Thank you, I guess so for E85, is just for price, I will upgrade my compression in some years with Edelbrock Performer RPM heads (75 cc) and KB237 pistons, I will be around the, 10.6/10.7 to 1.
Old Mar 17, 2019 | 10:14 AM
I will add that going from 8 to 1 to 13 to one with light pistons will give you 50 hp and a substantial increase in torque more than 50 ftlbs.
Old Mar 17, 2019 | 10:15 AM
Sounds about rite to me
E85 4.0 - 5.0 MPG
Unleaded 87 Octane 8 - 10.0 MPG
Old Mar 17, 2019 | 10:20 AM
Yes ! Can't wait to upgrade my 440
Old Mar 17, 2019 | 10:27 AM
E85 4.0 - 5.0 MPG
Thank you. The Holley EFI is new, I will keep you update, with the time the EFI will learn, and maybe 1 or 2 advices from EFI professional will incrase MPG. But I didn't purshaded a 440 for good MPG, I'm just asking for know if everething is fine.
Old Mar 17, 2019 | 12:47 PM
I think rite now... The cam is too big.... And The Intake is not a dual plane... That is what is hurting the mileage the most rite now.. I think things will be better when all things in the engine is matched.. Just my 2 cents.
Old Mar 17, 2019 | 01:51 PM
For real I look the performer RPM intake since a long time, but Torker 2 is just below so I keeped my money for the heads and piston. I never put off the heads for seen the pistons, but (I'm not an expert) I thing I'm around the 250 HP, too bad for a high performance engine, the guy who put this engine on the Challenger as begun a good job with this engine, maybe money stoped him, or maybe he didn't have the time to finish that, I imported the car in France, after a search on internet I seen the old owner is missing...
Apewalski70
Jan 19, 2020 12:41 PM
Apewalski70
20
Apr 17, 2018 06:12 AM
64Imperial
63
Feb 15, 2016 07:44 PM
Mango
Nov 24, 2010 03:30 AM
deadkelly
Sep 21, 2008 05:26 AM
