440 total timing?
Old Dec 20, 2013 | 06:21 PM
440 aspen's Avatar
440 total timing?
what should my total timing be on my 440?
77 440 .040 over, about 8:1 compression, 509/292 cam, I think 4.11 gears
Old Dec 20, 2013 | 06:52 PM
That cam 15 initial 34-36 total.
I would set initial with vacuum gauge to get the most vacuum then adjust mechanical advance to get total without ping. May take a few tries, but worth it with that low compression.
Old Dec 21, 2013 | 06:15 AM
I do 15 then 20 in at 2500 for a total of 35.
Old Dec 21, 2013 | 07:27 AM
I agree.....
However i like to do it a little differently.....
With everything hooked up...Run the engine up to 2500RPM and set the timing @ 34*.... tighten up the bracket... reset the curb idle... and test drive it....
Just my 2 cents
Old Dec 21, 2013 | 09:51 AM
I run a MSD distributor so you do it with a cam and a spring.
BillsBaby
Apr 30, 2018 09:38 PM
sendust
Jan 10, 2014 05:51 PM
Gorts 5th
Dec 19, 2012 04:52 PM
a.johansson84
May 27, 2012 03:30 AM
Barfly
Jun 9, 2010 08:04 PM
