750 Holley flooding.
I have a Holley 750 double pumper with mechanical secondaries and manual choke on a 383. I can't stop it from overflowing with gas, Iv'e adjusted the floats a number of times so I'm pretty sure there right, Also this carb. is fairly new and looks to be in good cond. I am running 6 to 6.5 psi on the fuel, Is this to much for this carburetor?
I set the floats dry started it up and fuel started coming out the vent, So I backed off the set screw and turned the float adjustment clockwise 1/2 turn. The fuel still comes out the vent. I assumed that the pressure was to high at 6 to 6.5 lb.
76 Doba
May 26, 2011 02:24 PM
