750 Holley flooding.
Old May 9, 2018 | 08:29 PM
Kitzy's Avatar
I have a Holley 750 double pumper with mechanical secondaries and manual choke on a 383. I can't stop it from overflowing with gas, Iv'e adjusted the floats a number of times so I'm pretty sure there right, Also this carb. is fairly new and looks to be in good cond. I am running 6 to 6.5 psi on the fuel, Is this to much for this carburetor?
Old May 9, 2018 | 09:23 PM
Are you adjusting it while running or dry/bowl removed. I would suspect the float needle is damaged or the float is bad.
Old May 10, 2018 | 05:47 AM
Kitzy's Avatar
I set the floats dry started it up and fuel started coming out the vent, So I backed off the set screw and turned the float adjustment clockwise 1/2 turn. The fuel still comes out the vent. I assumed that the pressure was to high at 6 to 6.5 lb.
Old May 10, 2018 | 06:05 AM
Archer's Avatar
k -
6 - 6.5 psi is normal. You are checking the pressure right before the carb, right?
Sounds like you don't have enough travel on the adjustment screw, but that's pretty rare.
Old May 10, 2018 | 09:17 AM
Make sure needles and seats are clean .
Old May 10, 2018 | 09:22 AM
https://www.bing.com/videos/search?q=adjusting+the+holley+float+levels+on+a+75 0&view=detail&mid=D3D3BE4069BEFA25772AD3D3BE4069BE FA25772A&FORM=VIRE
This
Might help..
Old May 10, 2018 | 02:53 PM
Kitzy's Avatar
I found the problem, It was the O ring on the needle and seat assembly. Thanks for all the help!
Old May 10, 2018 | 05:49 PM
Awesome
72NewYorker
Oct 25, 2014 06:32 PM
2002ram440
Dec 1, 2011 12:00 PM
76 Doba
May 26, 2011 02:24 PM
dodgenut7
May 25, 2010 10:34 AM
raycer5
Dec 17, 2008 02:22 PM
