Building 360 Magium water pump ? help
Hello Daryl here .. i'm building a 95 360 Magium hot rod engine and need to load a water pump on this engine...
Question is can i use an older 360 LA water pump? or must i use a newer 360 Magium pump.
I'm told they are 2 differant pumps & i must use new Mag pump
Also i'd like to load pulley system.... V drive if i can... will older LA brackets & pulleys fit?
Thanks in advance.... Daryl
they are for fact different pumps. get one for a magnum. idk about pullys but you might be able to fit a late LA style v belt water pump pulley onto a magnum pump. they are usually pressed on though...a 318 pump is the same and you can get one that allows you to bolt on a pulley usually from the 92-94 range in years.
The magnum water pump has a reverse rotation so watch you belt routing
But to answer your question yes you can use la pump . The blocks are the same in design with the latter having a roller cam.
Use LA timing cover on Magium block
on this newer 360 Magium block and then use older style water pump and V groove pulleys...?
Thanks in advance Daryl
