Building 360 Magium water pump ? help
Old Aug 15, 2012 | 02:43 PM
fastcoauto's Avatar
Question Building 360 Magium water pump ? help
Hello Daryl here .. i'm building a 95 360 Magium hot rod engine and need to load a water pump on this engine...
Question is can i use an older 360 LA water pump? or must i use a newer 360 Magium pump.
I'm told they are 2 differant pumps & i must use new Mag pump
Also i'd like to load pulley system.... V drive if i can... will older LA brackets & pulleys fit?
Thanks in advance.... Daryl
Old Aug 16, 2012 | 12:12 AM
78doubleR's Avatar
they are for fact different pumps. get one for a magnum. idk about pullys but you might be able to fit a late LA style v belt water pump pulley onto a magnum pump. they are usually pressed on though...a 318 pump is the same and you can get one that allows you to bolt on a pulley usually from the 92-94 range in years.
Old Aug 16, 2012 | 02:50 AM
PK1's Avatar
PK1
The magnum water pump has a reverse rotation so watch you belt routing
But to answer your question yes you can use la pump . The blocks are the same in design with the latter having a roller cam.
Old Aug 16, 2012 | 01:50 PM
fastcoauto's Avatar
Question Use LA timing cover on Magium block
Hello thanks for your help.... is it possible to older LA timing cover
on this newer 360 Magium block and then use older style water pump and V groove pulleys...?
Thanks in advance Daryl
Old Aug 16, 2012 | 02:08 PM
Yes no problem, block fuel pump mount if not used.
72Satellite440
Oct 13, 2010 10:29 AM
sixfive407
Sep 3, 2010 04:44 AM
Johnny677
Jan 6, 2010 01:30 AM
68 Sat
Oct 22, 2009 02:17 PM
Chall70
Sep 23, 2008 07:39 AM
