Building stock block slant six
What are some good combos or parts to beef up a stock block slant six, I don’t want to deck the block or touch the heads because I’m trying to budget myself but I would like to know what I can do to my engine to give it more power, I want to keep it n/a for now so I’m more or less looking for good cam and intake and carb combos or anything else I could do to get some Torque and power out of my motor.
The best way to get benefits from modifying the 6 is by increasing compression......to around 9.5 to 1. Otherwise your limited to a stock cam and you really don't need to get bigger on anything else. Maybe a decent exhaust, no header.
Bump compression then you can go bigger cam small 4 v carb and header. I know you don't want to here it but small turbo would work on the /6 very well.
I've got a feeling you've heard all this before but the low compression ratios kill performance options.
