Head Gasket Recommendation
Old May 19, 2018 | 03:44 PM
RBLowbucks's Avatar
Just freshened up my motor (rings, bearings, etc) and believe I have a head gasket leak. Motor is a 440, .030 over, 11:1 compression, pushing 450 to 500 hp. I've always used FelPro P/N 1009 gaskets in this motor, but am looking for a recommendation for something different. Motor holds cranking pressure, but when running is leaking pressure into the cooling system. No migration of other fluids. Anyone have a recommendation for a different head gasket. Looking for approx .039" compressed thickness to maintain the current quench clearance. Thanks.
Update:
I think I figured out why I am having a leak. The last trip to the machine shop for a cleanup hone on this block I had them put a very small chamfer at the top of the bores to aid with ring installation. At .030" over and with the small chamfer I am figuring that the equivalent bore at the deck is about 4.475". The Fel Pro 1009 gasket is only good for a 4.410" bore. It's sealing but not well at firing pressures. That being said I still need to come up with a different gasket since Fel Pro doesn't make one with a bore bigger than 4.410". Any one have any experience with Cometic or Trick Flow head gaskets?
Old May 20, 2018 | 04:46 AM
I recommend the Cometics.
Old May 20, 2018 | 06:47 AM
Cometic
Old May 20, 2018 | 07:19 AM
Plenty of good gaskets out there... Just get the rite bore size. and you should be good to go.. Providing everything else is good and flat.
Old May 21, 2018 | 06:46 AM
ZEN357's Avatar
I swear by Felpro gaskets!!!
Old May 25, 2018 | 11:06 PM
RBLowbucks's Avatar
Update. I pulled both heads and as I suspected the compression ring on the FelPro's just barely overhangs the chamfer at the top of the bores. I've always used FelPros but this time I'm trying the Cometics. FelPro doesn't make a gasket with the combination of bore size and compressed thickness that I need.
Old Sep 7, 2018 | 10:32 AM
Bicylindrico's Avatar
Currently running the Fel-Pro 17059 on my .030" over 440 without issue.
Old Sep 7, 2018 | 12:12 PM
that will fix you up.
Mikey123
Feb 15, 2019 02:55 AM
70newport
Mar 30, 2016 02:54 PM
josehf34
Mar 3, 2016 07:03 PM
74Runneer
Apr 13, 2013 01:55 PM
MarkyMark12345
Apr 16, 2009 06:46 PM
