High volume oil pump
Old Jul 3, 2016 | 07:11 AM
mizzou580's Avatar
Looking for opinions on running the Melling M63HV oil pump on a lightly modified 65 383. I'm concerned that it might swamp the top end and won't return fast enough. I'm assembling the engine now and have it on there but it's not too late to change back to a stock or maybe the HP. Any help would be appreciated.
Old Jul 3, 2016 | 07:27 AM
Whats YOUR purpose for the H.V. Pump ???
Old Jul 3, 2016 | 07:32 AM
mizzou580's Avatar
Just thought more is better
Old Jul 3, 2016 | 07:54 AM
Ok.... The problem comes "In the short Statement" If your going to run the stock oil pan, its a bad idea. The H.V. pump can do what you said and pull all the oil out of the oil pan and put it all up stairs..
If you going to be running RPM allot of the time, then you use them for that kind of a combo. Just be careful, not saying not to use it. But if this is more of a daily drive, I would go with a more high Pressure than a High volume pump.
Just my point of view.
Keep us posted.... Mopar on Brother >>>>
Old Jul 3, 2016 | 08:07 AM
mizzou580's Avatar
I was just thinking when I bought it that I wanted more volume but when o started putting it together I had second thoughts. I'm running a stock size pan and will mostly be cruising with an occasional high rpm to shake out the cob webs and have some fun maybe I should go with a stock or HP. Thanks
Old Jul 3, 2016 | 09:07 AM
HV pump = larger pan capacity
It's very simple, if your going to pull more oil you need more to draw from or you will be sucking air.
JS23
Dec 18, 2014 07:12 AM
hewhobarksatdogs
Sep 22, 2012 05:53 PM
ShowYourAuto.com
Mar 18, 2011 11:24 AM
getsum
Feb 7, 2011 02:54 PM
dzltd02
Oct 28, 2008 08:25 AM
