MSD Distributor Install
Old Sep 21, 2013 | 12:59 PM
68GTX440's Avatar
I bought a MSD #8387 Pro-Billet (Ready-to-Run) Distributor wanting to replace existing Chrysler Electronic Ignition system and it's original modified distributor.
Installation instructions state that this distributor does not need an MSD ignition module, as the distributor has a built in electronics system and it also does not need the in-line ballast, so if the original wiring includes a ballast, it can be bi-passed.
QUESTION #1
If I no longer need the Chrysler Ignition module, what do I do with all the wiring that goes to it, as two wires that come out of it, were connected to the old distributor?
QUESTION #2
I assume I still need the regulator in the circuit. I'm not sure if taking the old electronic ignition out of the loop will change the regulator's wiring or position within in the circuit?
Old Sep 21, 2013 | 01:10 PM
They are separate circuits. You can wrap it up out of the way or just cut it off and tape it up where it goes into the harness
69POLARA383
Feb 9, 2014 09:27 AM
buttton
18
Mar 1, 2013 06:22 PM
buttton
Feb 23, 2013 05:19 AM
3rd1970RR
Oct 14, 2012 04:28 PM
fmontez1
Jan 5, 2012 09:21 AM
