Piston ring end gap?
Old Aug 28, 2013 | 05:03 PM
1970 Polara's Avatar
Hey guys, I'm building a 440 for my Polara, I ordered this set of pistons:http://www.summitracing.com/parts/sl...5f/application .030 over and this set of rings: http://www.summitracing.com/parts/sl...0/applications. My question is what do I do for ring gap?
Thanks in advance for all input. Bill
Old Aug 28, 2013 | 05:31 PM
There should be info with the rings as to the required ring gap Or look it up on their web site
says standard ring gaps look in the service manual. don't have one handy
Old Aug 28, 2013 | 05:48 PM
Good stuff here: http://www.wiseco.com/PDFs/Manuals/RingEndGap.pdf
Old Aug 28, 2013 | 06:18 PM
moe7404's Avatar
this may not what fit your application but it is out a 1967 cnrysler factory paper service manual. 440 Ring Gap compression .013"-.023". Oil -Steel Rails .015"-.055" i am not up on even if steel rails are still used. hope this helps.
Old Aug 28, 2013 | 07:33 PM
You need to go by what the piston / ring manufacturer says, as some designs (I'm not into some of this newer stuff) are different than what the shop manual may have originally said
Old Aug 28, 2013 | 07:47 PM
You have to go by what pistons you buy.... The MFG. will have a finished bore size for there pistons... Then you can set the ring gap by there information...
Old Aug 29, 2013 | 05:12 AM
Racerhog is correct. The piston to wall clearance and piston ring gap information will come with the pistons.
Old Aug 29, 2013 | 12:32 PM
Thanks guys, I'll check that out, said nothing about end gap in the piston box though.
mongrot
Jun 17, 2012 03:40 PM
Panhead65
Mar 8, 2011 07:36 AM
H-Pattern
Jun 9, 2010 08:09 PM
Cracocuda
Dec 24, 2009 04:18 PM
rick_wa
Jul 13, 2008 01:27 PM
