Pushrod Help
Old Mar 11, 2022 | 06:23 AM
Woodsman2577's Avatar
Pushrod Help
Hei I'm in need of some knowledge I purchased a 69 GTX In parts with a 440 trying to reassemble.
I pulled the valve covers and pan and found the pushrods laying inside everything is been and tight but my pushrods are to short
my question is does the 440 use a pushrod keeper or spacer down to the tappets and crankshaft?
Thanks any help appreciated
Old Mar 11, 2022 | 06:49 AM
Depends of weather the engine is all stock or modified?
If it is a standard Push Rod>>>>
9.315 Lenght
5/16" Shaft size
Old Mar 11, 2022 | 07:16 AM
I believe they are the right ones I will measure but no spacer or keeper at the tappet they connect between lifter and tappet within rod indentation on both?
Old Mar 11, 2022 | 08:53 AM
Archer's Avatar
W -
No spacer on a stock valve train and stamped, non-adjustable rockers.
Old Mar 11, 2022 | 01:29 PM
Ball and Ball Push Rod... Dose the push rod look Similar like this?
Without the Hole in the middle?
These do not require any holder... Just the lifter and the rocker arm pocket.
Srlawrence05
13
Jul 19, 2017 07:06 AM
black68gtx
24
Aug 11, 2015 01:46 PM
aatkinsonalexdatkinson
Feb 1, 2012 08:13 AM
joe440
Mar 6, 2009 04:27 PM
DistanceFailing
May 1, 2007 12:46 PM
