Timing preference
Old Aug 2, 2013 | 06:29 PM
1968newport's Avatar
Timing preference
What do you guys prefer: timing belt, chain or gear drive?
Old Aug 2, 2013 | 07:43 PM
Timing chain. Gear drive is too noisy.
Old Aug 2, 2013 | 09:48 PM
definitely a chain !!
Old Aug 3, 2013 | 07:57 AM
All the above depending on application...
Old Aug 3, 2013 | 08:08 PM
Thanks! I am going with a quiet chain.
Old Aug 3, 2013 | 10:48 PM
Archer's Avatar
1968 -
You want a good double-roller timing chain set up.
Can't tell you if they are quiet or not, the engines usually make too much noise ...
Old Aug 4, 2013 | 08:58 AM
Archer, who would you recommend for a manufacturer? What am I looking to spend on it?
Old Aug 4, 2013 | 09:26 AM
Archer's Avatar
1968 -
I usually just stay with the company who made the cam when possible.
Comp Cams, Cloyes, Edelbrock, Even Summit and Mopar have good sets.
Billet sets might be a little better, but more pricey.
Still given what you have in the engine, even the more expensive sets wouldn't be a bad investment.
Old Aug 4, 2013 | 12:21 PM
Napa Auto Parts....
Old Aug 4, 2013 | 01:04 PM
Drag Pak's Avatar
RollMaster has always made a good set.
http://www.romacusa.com/
Old Aug 4, 2013 | 03:13 PM
PK1's Avatar
PK1
When getting a chain ,gear, belt consider its adjust-ability if you need to get that cam in a certain spot. There are only a couple of manufacturers in the game and many are just renames for different vendors. Same part... different box. The ones above are all good IMO.
Old Aug 4, 2013 | 04:32 PM
pro-tech's Avatar
You diffenetly want a double roller NOT a silent chain they have a tendency of stretching and can throw the cam timing off. Also they can jump time and do serious engine damage if they do jump...The cost difference is minimal between the two....Bill
Old Aug 4, 2013 | 08:00 PM
Excellent. Thanks guys!
Old Aug 5, 2013 | 06:37 AM
Dave E's Avatar
The thought of a timing belt makes me cringe! If I could take out and exchange for chain every vehicle I have had with a belt I would do it!
19newport72
Mar 27, 2024 06:44 PM
Commando
Nov 19, 2013 06:45 PM
Gorts 5th
Dec 19, 2012 04:52 PM
a.johansson84
May 27, 2012 03:30 AM
Drakovich
Apr 21, 2011 09:23 PM
