Timing preference
1968 -
You want a good double-roller timing chain set up.
Can't tell you if they are quiet or not, the engines usually make too much noise ...
Thanks! I am going with a quiet chain.
1968 -
I usually just stay with the company who made the cam when possible.
Comp Cams, Cloyes, Edelbrock, Even Summit and Mopar have good sets.
Billet sets might be a little better, but more pricey.
Still given what you have in the engine, even the more expensive sets wouldn't be a bad investment.
When getting a chain ,gear, belt consider its adjust-ability if you need to get that cam in a certain spot. There are only a couple of manufacturers in the game and many are just renames for different vendors. Same part... different box. The ones above are all good IMO.
You diffenetly want a double roller NOT a silent chain they have a tendency of stretching and can throw the cam timing off. Also they can jump time and do serious engine damage if they do jump...The cost difference is minimal between the two....Bill
a.johansson84
May 27, 2012 03:30 AM
