Valve Swap 360 to 318
Old Feb 15, 2013 | 09:37 AM
Krueggs81's Avatar
What would it all day to put a set of valve from a 360 head into a 318 head? Or will they just slide right in? Or what do you gotta do?
Matt
Old Feb 15, 2013 | 12:43 PM
68plymouth383's Avatar
Why not just swap out the whole head?? The 318 340 360 la engine heads interchange.
Matt
Old Feb 15, 2013 | 12:54 PM
Krueggs81's Avatar
Because the chamber is bigger on a 360 head and you lose compression. Been reading alot on this on a bunch of different sites and forums of how the compression drops so low..
Old Feb 16, 2013 | 09:51 AM
Yeah, so you just shave it thirty thousandths and go for it.
Old Feb 21, 2013 | 10:26 AM
Gorts 5th's Avatar
Smile
depending on the year the compression drops more or less
i run 360 heads on my 318... stock valve sizes but ported to the max
i basically traded velocity for volumetric efficiency it works.
i notice a gain in upper end performance where the 318 heads fell off.
say around 4000-6500-7000.
then later i had the heads milled, made it better.
i would swap the heads in a heart beat, mill em like Skwerly recommends.
Old Feb 21, 2013 | 07:15 PM
Chryco Psycho's Avatar
you can open up the seats , I would install hard seats on the exhaust side & put in the larger valves , I would also use a 302 casting 87-92 to do this
Old Feb 22, 2013 | 06:54 AM
Gorts 5th's Avatar
Smile
Not knocking the 302s i read 318 builds with this head ported and valves maxed out producing 400 hp that's serious power, i have a set of 302's i might port polish and max the valves... i'm curious.
74Runneer
Oct 17, 2015 10:32 AM
jej
Nov 17, 2014 07:59 AM
Manoharvalves
Sep 15, 2011 10:53 PM
notta _mech
Sep 13, 2011 09:42 AM
keith811
Jan 13, 2011 10:43 AM
