727 problems.
Old Mar 3, 2014 | 10:54 AM
Colorado_Fury's Avatar
727 problems.
So I figured I'd ask before diving in and rebuilding my whole transmission. It is in drive regardless of what gear I shift it into. If it's in a forward gear it goes forward, if it's in neutral it goes forward, if it's in reverse it tries to go forward and backward at the same time, and if it's in park it tries to go forward but the parking pall holds it still. Should I rebuild or is there something less intense that's gone wrong. I've never had this problem with any other car so this is my first time troubleshooting something like this. Hope to get an answer ASAP so I know what to spend my money on. Thanks for any advice!
Old Mar 3, 2014 | 11:11 AM
John Van's Avatar
sounds like the rear clutch is dragging. I would change the fluid and filter first to see if it helps. get a good tranny service manual like ATSG's.
good luck,john
Old Mar 3, 2014 | 11:29 AM
It probably is an internal problem. Before tearing it apart I would check the shift linkage and the detent. Make sure the trans levers are tight !
Old Mar 3, 2014 | 11:38 AM
Thanks guys, how do I check the detent? I was wondering if it could also be a band problem? The linkage seems fine.
Old Mar 3, 2014 | 12:32 PM
You can feel the detent when you move the lever
xvodysseusvx
Jun 25, 2018 04:38 PM
440 aspen
13
Apr 12, 2013 02:43 PM
pipdog69
Mar 13, 2012 11:01 PM
motoadam
Mar 22, 2011 09:41 AM
RandyYJ
Mar 13, 2009 01:59 AM
