727 rear clutch problem
Old Jul 6, 2015 | 06:56 PM
perussi's Avatar
Hi, I have a '69 superbee, and recently I restored the transmission. Worked fine about of 200 miles, but yesterday the morning I had problems with 727. Suddenly, the tranny started slips. In park, neutral, drive or low, still moving forward, but in reverse the tranny brake. Accelerating fairly moves with difficulty to reverse.
Today I have disassemble and find the rear clutch discs fully burned and "bended". Everything else seems ok.
The question is: may what have caused this? Valve body problem ?
I will replace the clutch discs, but I would like to know what may have caused this. Has someone an idea where to look for a possible assembly fault?
Thanks
Alex Perussi
Attached Thumbnails 727 rear clutch problem-img_2497_resize.jpg   727 rear clutch problem-img_2495_resize.jpg   727 rear clutch problem-img_2494_resize.jpg   727 rear clutch problem-img_2493_resize.jpg
Old Jul 6, 2015 | 08:10 PM
Drag Pak's Avatar
Post a picture of the inside of the clutch drum !
Old Jul 7, 2015 | 07:43 AM
perussi's Avatar
The piston seal is damaged. Piston also have damage. Can be a assembly fault in rear clutch piston ?
Attached Thumbnails 727 rear clutch problem-img_2499_resize.jpg   727 rear clutch problem-img_2504_resize.jpg   727 rear clutch problem-img_2502_resize.jpg
Old Jul 7, 2015 | 09:12 AM
Drag Pak's Avatar
The bellville spring (first picture )(16-425-5 in exploded view)is in backwards/upside down! And obviously the seal is pooched.
when installing the piston , use a twisting /turning motion to get it in smoothly(with lots of lube)!
Old Jul 7, 2015 | 09:46 AM
perussi's Avatar
Ops !!! Thanks!
Old Jul 7, 2015 | 11:27 AM
Good catch. Reminds me of my first trans experience with a Corvair PG put something in backwards and had no Hi gear
pops1967GTX
Nov 7, 2010 08:23 AM
1cerberus4u
Apr 18, 2008 06:55 PM
bigbadsrt
Mar 21, 2008 09:32 AM
gotdust
Jan 31, 2008 02:41 PM
gotdust
Jan 31, 2008 02:32 PM
