2009 challenger lights flicker
Old Jun 29, 2013 | 06:15 AM
mooregw's Avatar
i have a 2009 challenger r/t it has 4400 miles on it when you rev it up everythings fine when it goes back to idle the head lights will flicker i replaced the altanator and it did the same thing has anyone ever heard or seen this before thanks
Old Jun 29, 2013 | 01:53 PM
Phatchanz's Avatar
Most likely your lighting control module. The actual replacement procedure for the module is simple, the price-tag however is not.
Old Jun 29, 2013 | 07:07 PM
mooregw's Avatar
where is this lighting control module located thanks
Old Jun 30, 2013 | 12:05 AM
Phatchanz's Avatar
After a little research, I found that the Front Control Module (FCM) is the one that controls the headlights in the newer Mopars. Most of the time, that is located near the power distribution box in the engine compartment.
Before replacing the module, try disconnecting your negative battery cable for about 5 mins. Then clean the battery terminals and reconnect the cable(s). That may provide a temporary fix. Also, with the older vehicles, when lights flicker it is an indication that the alternator is going out or that there is a loose ground. Though I doubt that is the case for you, it is always worth a check. Most part stores will test your alternator for free.
Old Jun 30, 2013 | 09:51 AM
I would check to see if there is a relay in the circuit
AliceSML79
Aug 22, 2014 03:28 AM
1966charger
Apr 22, 2012 08:27 PM
TeamDart
Mar 17, 2009 03:46 PM
familyevents
Dec 10, 2008 10:09 AM
