Electric fan Wiring??
Old Jun 18, 2014 | 05:55 PM
hckrphil's Avatar
When wiring up your electric fan w/ thermostat... Do you wire it to accessory power or constant power so it stays running even after shutting the car off??
Mine is on accessory now, might switch it to constant so it keeps cooling for a little bit after...
Thoughts??
Old Jun 18, 2014 | 06:20 PM
Mine is switched....... You could try it and see if it helps....
But I think you have to deal with the sealing problem and then the rest will work a little better....
Old Jun 18, 2014 | 07:59 PM
Buffalojoe426's Avatar
Leave it on accessory. It can drain down your battery if you have it on hot all the time. Besides if your water pump isn't pumping a fan wont do much good for cooling the engine.
Old Jun 19, 2014 | 07:46 AM
Well if you are going to do that, you do not want it on "accessory." You want it on "ignition."
mopartruck
Jul 29, 2014 12:40 PM
B5Dart69
Apr 10, 2014 02:40 PM
TxDakota5.9
Apr 24, 2013 09:40 AM
440-4x4
Aug 14, 2011 04:46 PM
SixFoPolara
Aug 3, 2009 05:08 PM
