No spark 72 Fury III
Old Jan 26, 2017 | 08:17 PM
Cori Mielke's Avatar
Hi there! My guy had a 72 Fury III he had to sell (was a daily driver when we sold it) this year I bought it back. The people who had it, messed with it. The car had some trouble starting when we went to pick it, my guy discovered lose connection to the coil. He tightened it up and the car started. Now we've had it a week and it started once, but since then no spark. New coil, new Ignition Module, looks like a new solenoid recently (not by us) replaced plugs, cleaned up wires from corrosion, checked connection on ballast, checked fuel lines and it still not starting. We just tested for spark...nothing. Engine cranks but wont kick over.
what are we missing?
Old Jan 27, 2017 | 05:25 PM
Drag Pak's Avatar
Make sure you have an excellent ground to the ignition module. I have even run astand alone ground straps to the ignition module.
Old Jan 27, 2017 | 06:42 PM
With all that has been done ? I would check into the distributor pickup inside the distributor. Look for melted wax under it...Buy a good quality one if it is bad. I had a 79 Van 360 and that is the only part of the ign I ever had to replace...
Old Jan 31, 2017 | 05:49 PM
This. I found out the hard way.
Cori Mielke
Jan 29, 2017 08:03 PM
josehf34
Dec 14, 2015 07:34 AM
buttton
Apr 1, 2013 10:00 AM
austin
Sep 18, 2012 12:37 PM
66FuryBoy
Mar 16, 2011 02:30 PM
