Some pictures of my latest project
Old Jan 22, 2009 | 04:47 AM
  #31
Crazy4Carz.Com's Avatar
The engine should be back soon, so I decided to do a little plumbing. The fogger kit is now installed. the jet sizes are 39 and 37. According to NOS and Nitrous express this should make 400 to 440 horsepower. This is a lot of bending and cutting tubing. Everything is roughed in and I still need to take it all apart and seal everything (locktite and teflon). I decided to take a pic before it all comes back apart.
It is sitting on some blocks with the valve covers at the right height and angle so that it all fits when the engine is installed.
Old Jan 22, 2009 | 04:55 AM
  #32
Polaradude's Avatar
Thats just pretty, nice work man.
Old Jan 22, 2009 | 04:42 PM
  #33
awsome looking engine
Old Jan 23, 2009 | 03:46 AM
  #34
I like how you took the sheetmetal over the rear tires and opened it up for the larger tires. It looks stock. You have done some really great work on that car.
Old Jan 23, 2009 | 04:17 AM
  #35
A "stock" type look was what I am going for. In '68 the Hemi superstock cars were modified by Hurst. The wheel openings were modified, A-100 van seats were installed, the same scoop as you see here, as well as several other race modifications. This car is built as a tribute car to the lod superstockers. Rather than the old heavy 426 I am using a late model hemi stroked to 426. As for the sheet metal, I purchased a template of the "factory" superstock cars and coppied that.
Thanks, I am glad it is recieved so well.
Old Jan 23, 2009 | 06:50 PM
  #36
it looks amazing
Old Jan 24, 2009 | 04:06 PM
  #37
A couple teaser pictures. I was in the garage today, I finished up the intake. Everything was dis-assembled, blue locktited, sealed tightened, aligned, and I had nothing better to do so........
I thought, 'wonder how it's going to look under the hood? So I grabbed a couple broom handles and....
From the front,
I know I'm like a little kid. The engine is comming home this friday and I will be installing it along with the trans and exhaust next weekend.
Old Feb 1, 2009 | 03:11 PM
  #38
Monitoring fluids is always important, but not running lean is extreemly important in a Nitrous engine. A lean condition can make a virtual cutting torch inside the engine and fry it in a couple seconds. Fuel gages had to be added to montor fuel pressure at various engine speeds and RPM's at different times/conditions. There are several options. I could use remote pressure units and electric fuel pressure gages. There were basically two reasons I didn't like this idea. First, I believe mechanical is more accurate, Second the price for that set up is outrageous (and I need two)
I elected to mout these on the hood. We looked at the cowl, but the plumbing and wiring was an issue. the hood made the most sence. There are two because I need to monitor both the nitrous fuel system and the engine/carbs system. There are two separate systems from the two fuel pumps all the way forward.
Old Feb 1, 2009 | 03:15 PM
  #39
Have you ever seen inside a late model hemi head? Here is mine with oversize valves. Don't bother looking to buy these, they don't make them. These were custom made for this engine. The ports have been worked a lot, and the seats have been cut well. Not many people get to see the inside of these heads so I thought I would post these up.
Here is a picture of the assembled block before the heads go on. The guy in the picture is Scott. He is the machinist performing this miacle. You can also see how domed these are compared to stock.
Old Feb 1, 2009 | 03:57 PM
  #40
Polaradude's Avatar
Nice spring relocation, nice job man, nice fab work. She's a mean lookin' Mopar.
What size are those valves?...hahaha and what cc are the combustion chambers, thats wild lookin.
Old Feb 3, 2009 | 05:55 AM
  #41
Polaradude's Avatar
One more question, Did it start life as a 69 ? I was just wondering about the grill in the original before pic. It went from rectangle park lights to round..just curious.
Old Feb 3, 2009 | 01:31 PM
  #42
It started life as a 6cyl automatic 1967. Many will argue that a '67 cannot be converted to a '68. It can. Tail lights were changed, grill and headlight rings were changed, Side markers were added. The sidemarker lights were added to the rear quarters only for a specific reason. In 1968 when Hurst did the Hemi conversions on these darts, a fiberglass front end was added with hood and fenders. the front marker lights were never converted over to the fiberglass front fenders. So, to add to the illusion, I left the front fenders blank without the front/side marker lights. also the white interior was switched to the '67 blue. A-100 Van seats were used as in the factory superstockers.
Good eye with the front light observation.
Old Feb 3, 2009 | 03:59 PM
  #43
Polaradude's Avatar
Thx, I have to tell ya, that's a very impressive build. I couldn't be any more serious about it, very nice, as you can tell I've been looking close.
Old Feb 4, 2009 | 01:23 PM
  #44
1 Bad Mirada's Avatar
Administrator
thats a nice dart...excellent work. what are you expecting it to run?
what made you go with the bottle setup over big NA?
Old Feb 4, 2009 | 04:06 PM
  #45
I'm hoping for mid to low 9's. I can't get 1000 horsepower out of the engine alone. I am looking at ~600+ on the engine and ~400 spray.
Old Feb 5, 2009 | 08:42 AM
  #46
Administrator
wicked...
is it streetable too?
Old Feb 5, 2009 | 04:01 PM
  #47
challenger's Avatar
hey c4c im going to go out on a limb and guess that you will run a 10.03 so wright it down and let me no how close i am as always its looking sweeter by the day and cant wait to get a ride in it hehehe
Old Feb 5, 2009 | 06:15 PM
  #48
wicked...
It got tagged as an antique while it was a slant six. With antique tags in Delaware there are no more inspections just pay every year for my tags. It is going to be street driven. With the 4.57:1 gears it wont cruise fast.
I am going to pick up the long block (block with the heads installed) Friday!! Only a little time and it will be back in one piece!
Old Feb 6, 2009 | 03:02 PM
  #50
Originally Posted by 66sportfury
you will see a 440 powered mazda truck.
huh?
Old Feb 6, 2009 | 04:49 PM
  #51
Thats a waste of a 440. Should be in a dakota.
Old Feb 6, 2009 | 07:43 PM
  #53
HEY! Keep on topic!
I spent all day in the garage today and made significant progress. Here is the engine now!
Old Feb 6, 2009 | 07:56 PM
  #55
sweet what are you using for ignition.
MSD
Old Feb 6, 2009 | 09:36 PM
  #56
Administrator
im loving the vintage looking carb stacks...
Old Feb 7, 2009 | 02:40 AM
  #57
That is looking great! What are you using for a tranny behind it?
Old Feb 7, 2009 | 04:12 AM
  #58
727 with a manual valve body. It is a reverse shift pattern meaning it goes, P-R-N-1-2-D shifting away from reverse and neutral. the 727 is also set up with a trans brake. I'll be launching the car ~3800 off the transbrake. May be kind of violent.
Old Feb 7, 2009 | 05:11 AM
  #59
It may be a little violent, but with how you have been building it, I'm sure that it can handle it.
Old Feb 7, 2009 | 05:51 AM
  #60
Administrator
interesting..ive seen a handful of the most violent eruptions from transbraked 727s...ive been running a footbraked 727 with a 4000 stall and a forward manual body for a few years, and i wouldnt go to a transbrake, as it is SO hard on the drivetrain, but im not launching a 1000hp car...
what shifter are you using? cheetah?
by the way, in looking back through the pics, this is the one that really stands out as being a wicked looking drag car..
maybe its the fact that the rear tires are 10 times wider than the fronts..maybe its the chute..
