Weird click sound when u turn the steering wheel
Old Sep 29, 2017 | 10:08 PM
D4Dartswinger's Avatar
so when I'm driving as I turn left , on the first rotation there's like a knock or click sound. I can feel it in the steering wheel. Mostly happens when I turn left. Any ideas? . And sorry if this is a loaded question but I have a hole that the steering column goes into(causing lots of heat to hit my legs . I was told that this plate that the column goes through, that's on the inside of the car should be on the outside. This sound familiar to anyone? I'll post pics tomorrow.
Old Sep 30, 2017 | 07:00 PM
The orange is the engine block
Old Sep 30, 2017 | 08:11 PM
That would do it !!! And your going to saw a hole in the oil line tubing also, might address that while your at it....
Old Oct 2, 2017 | 10:47 AM
Is that plate on correctly? Or am I missing something that plugs that hole to the engine
Old Oct 2, 2017 | 04:06 PM
You need a missing gasket/seal and to replace the broken off bolts... there are 3 bolts that secure the plate to the firewall...
Old Oct 2, 2017 | 07:17 PM
hmmm ok thanks I'll try to do some googles and figure out what those might be
Old Oct 2, 2017 | 07:51 PM
Something like this.. >>>>> https://www.ebay.com/i/260436315544?chn=ps&dispItem=1 <<<<<<
And look in the upper L.H. Hole... The mounting bolt is broken off inside the weld nut.
ahrkar
Sep 18, 2012 10:27 AM
ahrkar
Sep 13, 2012 08:03 PM
1 Bad Mirada
Sep 14, 2010 01:12 PM
sgp7679
Apr 11, 2009 02:40 PM
youngtwister
Dec 27, 2008 03:55 PM
