Starter question...
Old Sep 2, 2013 | 02:27 PM
Dave E's Avatar
Starter question...
To keep this short.... I am swapping a 1998 Magnum 360 into my old '86 W250. I am still using the truck while the Magnum is being built. Today my starter decided to take a crap. I had the entire donor truck for the '98 magnum so I just swapped in the starter from it. Bolted up fine aside from having to open the small starter solenoid terminal on my cable up just a bit. My question is this... has any one had this swap done for any length of time? are there any ill effects from doing this... ie starter gear wear, flywheel wear, damage of any sort? My concern is the differing number of teeth on a magnum and LA style flywheel. Any input would be helpful!
Old Sep 2, 2013 | 02:33 PM
pro-tech's Avatar
NO if fact everybody is using the magnium starters on there LA engines because they are smaller and faster. They are compatible and there should be no need for concern...Bill
Old Sep 2, 2013 | 04:02 PM
Dave E's Avatar
Sweet thanks! I thought that this was a common swap but I wasn't sure and wanted some corroborating evidence. It's kind of amusing to get in my old 86 hit the switch and hear a newer truck firing up. I am just awaiting (kind of impatiently) my freshened up Magnum 5.9 to finish this swap and move on to the next thing!
Old Sep 2, 2013 | 05:37 PM
pro-tech's Avatar
It will be sweet thats for sure...Bill
Old Sep 2, 2013 | 09:19 PM
slade's Avatar
my dakota has 78 318 i used my magnum starter like bill said there far better
Old Sep 3, 2013 | 05:24 AM
Dave E's Avatar
Oh yeah... right away I noticed how much faster and easier the starting was. She spins right over. I pulled the old starter apart to see if I could just rebuild it as an emergency spare and I found it was full of dried mud.
Old Sep 3, 2013 | 06:36 AM
pro-tech's Avatar
Well you say its a off road truck and off road trucks love the mud. The muddier the better...Bill
67gtxclone
Mar 12, 2010 11:25 AM
dodgecharger72
Sep 22, 2009 07:26 AM
Bossta
Sep 15, 2009 06:11 AM
Hot69hardtp
Dec 30, 2007 06:21 PM
sgoffena
Nov 9, 2007 07:55 PM
