Wrong alternator?
Old Dec 12, 2016 | 06:40 AM
1970ccc's Avatar
Wrong alternator?
Can someone verify that I need an alternator with 2 field posts for my 1970 Belvedere 318 car? The one that is on there now is a one field with a ground post (pre-1970 I think) and they did not properly modify the wiring. Hence, the blue wire from the alternator is missing ALL the insulation!
Should the new one look like this one:
Old Dec 12, 2016 | 06:41 AM
1970ccc's Avatar
This is like the one that is on there now (pre 1969, correct?):
Old Dec 12, 2016 | 07:34 PM
Mr.4spd's Avatar
Yes, you need the dual field model. Sounds like you already knew that though, what's up?
Old Dec 13, 2016 | 07:16 PM
Should use the 2 field...
Old Dec 14, 2016 | 08:39 AM
1970ccc's Avatar
That was it. Wrong alternator. Charging fine.
thanks for the help!
Old Dec 14, 2016 | 09:17 AM
Yey
Old Dec 14, 2016 | 05:51 PM
Good Deal.... Those will charge like hell if you full field them.. Cook a battery in no time at all.....lol
Glad you fix that issue...
mahd
Jun 17, 2009 09:06 PM
beuvyler
Pro-Stock
Jan 11, 2009 05:33 AM
beuvyler
Oct 6, 2008 02:43 PM
azzkikr
Mar 3, 2008 08:45 PM
rampage_82
Dec 7, 2007 08:22 AM
