Problems problems problems
Old May 6, 2009 | 11:51 AM
scotts74birds's Avatar
Dot think thats the TPS. Its probably the a/c idle solenoid
Old May 11, 2009 | 04:07 PM
Polaradude's Avatar
Do you think there would be anything left if you took the intake off ? Like a piece of the bolt to grab, ya know what I mean. Or enough there to heat around it and then try the ez out/drill combo. Sounds like a nightmare bro, keep us posted and we will help if we can.
Old May 11, 2009 | 07:58 PM
K, is there any part of the bolt still exposed above the surface? Very important!!! What I've seen the toolmakers do at work is take a correctly sized nut and place it over the stud and puddle or plug weld the nut to the broken stud and then just unscrew it cause the heat from wwelding loosened the whole thing up. Good luck!
Old May 12, 2009 | 12:29 PM
Polaradude's Avatar
Is there enough metal around where it went in to try a drill/easy out/Moovit and a little heat ?
Old May 13, 2009 | 01:18 PM
Dont be so quick to dismiss heli-coils. Properly done they are plenty tough.
Old May 23, 2009 | 11:19 PM
challenger's Avatar
the only problem with heli's is they are only so long from your local parts store at least what i have come across but there are companies out there that do make longer ones so maybe some one here might no where and i no they do work good when installed properly
Old Jun 25, 2009 | 01:17 PM
challenger's Avatar
did you geter fixed ???????
Old Jun 25, 2018 | 04:38 PM
Trail Duster's Avatar
Bolt is in head, not block for manifold.
Myself, I would pull the head and have that repaired right. Then put it together and not fret no further.
And check the rest of those holes. And finally I would use new stainless bolts to make ir perfect.
Shrug
Sep 3, 2013 03:57 PM
Ckurish1367
Aug 28, 2012 09:02 AM
Red Devil
20
Apr 18, 2011 06:05 PM
sgnrulz
Jan 13, 2010 09:03 AM
nesparky
May 26, 2009 07:37 AM
