1974 cuda w/ 440 hp torque converter
Old Sep 29, 2012 | 09:57 AM
Chryco Psycho's Avatar
If the 440 has a steel crank with then thin damper approx 1" wide then no weights are needed to balance it , if the front damper is over 1" thick most are tapered & closer to 2" thick it has a cast crank & will need weights on the converter or flex plate .
Old Sep 8, 2017 | 04:08 PM
Gorts 5th's Avatar
Hey all.
sounds like a tork converter failing....
The bearings are failing causing the "turbines" to miss alighn causing noise and generally lousy performance.
Untill lockup ingaged then u got all ur per formance.back
Can a pump fail? Or make noise?
yep.but diffent noises...and i like to add that the pump usually looses pressure. Before noise and a tork converter makes a wine or buzz..in my experience.
67Polara
Jul 28, 2012 01:49 PM
Minnesota Guy
Oct 21, 2010 10:41 AM
Nomadci
Aug 23, 2010 02:50 AM
smackhonda
May 26, 2010 07:17 PM
68 gtx
Oct 16, 2009 03:43 PM
