rebuilding a carter avs
Old Jan 5, 2009 | 06:40 AM
Polaradude's Avatar
If you can remove all plastic/rubber bits from the carb soak the whole thing in paint thinner. lacquer thinner preferably for 24 hours or longer if need be. It should help.
Old Jan 5, 2009 | 07:17 AM
Welcome to the forum!
I know there are rebuild kits out there on the net for Cater carbs. There is a local shop to me that rebuilds them all the time. As for cleaning, I also would go with the lacquer thinner or even kerosene to soak it in. Then use a hard nylon or brass brush to scrub it. Wear gloves, dusk mask (at least) and goggles. you can use an SOS or brillow pad as well.
Old Jan 5, 2009 | 07:48 AM
Commando's Avatar
I know you said that it is hard to get chemicals from the US, but have you checked around for brake cleaner or carb cleaner, you might get lucky.
I also heard diesel is pretty good at cleaning stuff up by soaking it, I am also going to assume that any of the chemicals are going to eat through any plastic, rubber, or gaskets.
Old Jan 5, 2009 | 01:05 PM
i use paint thinner too
josehf34
Jun 12, 2014 04:54 PM
72demon440
Sep 13, 2013 10:02 PM
Gorts 5th
Sep 14, 2012 05:31 PM
Rex 360
Dec 26, 2009 04:34 AM
KyleLR
Nov 2, 2009 04:57 PM
