filler cap question
Old May 14, 2017 | 04:42 PM
t65fury3's Avatar
oil filler cap question
i have a 65 plymouth fury lll with a 318
this seems odd i have a holley carb on my car but i don't think the book shows a holley carb I'm missing something please help i think i have this problem and maybe it has something to do with the oil filler cap question i have as well
just want to be sure i have the right cap in my fsm it states a closed vent system in one figure or a open system how can i be sure the cap does not have a tube on it to connect it to carb yet from the carb to no where is a hose connected to nothing. also the air cleaner has no hole in it for a hose to fit into.im stumped.
Old May 14, 2017 | 06:47 PM
The passenger side should have the small unit with the PCV valve in it that goes to the carb... The Drivers side should have just the breather cap....
Stant P# 10071 Cali Emission
Stant P# 10061 Non - Emission
hope that answers the question....
Old May 14, 2017 | 07:10 PM
t65fury3's Avatar
thats what I'm not sure of is it the california one or the non one not sure
Old May 15, 2017 | 11:16 AM
If the Air Cleaner has the nipple for the hose from the air cleaner to the breather. Thats the Cali Emission one....10071
If the Air Cleaner Dose Not have the nipple.... You have the Non-Emission
10061
Old May 15, 2017 | 03:03 PM
t65fury3's Avatar
10061
further help needed I'm not sure i have the right carb no one shows a holley carb for my 65 with a 318.carter bbd stromberg i think this is where i need to start
Old May 15, 2017 | 04:15 PM
t65fury3's Avatar
proof i can't decided
air cleaner no opening for tubes.top to bottom.
carb holley i show nothing on a holley for my car.
breather cap no nipple lastly carb has vent tube for nipple to breather cap.
what is the proper carb?or oem style or new plug and play.
is the a california emission car
or is it not i can't tell for sure.
Attached Thumbnails filler cap question-20170515_185921.jpg   filler cap question-20170515_185928.jpg   filler cap question-20170515_185938.jpg   filler cap question-20170515_185950.jpg   filler cap question-20170515_190115.jpg
filler cap question-20170515_190122.jpg   filler cap question-20170515_190132.jpg
Old May 15, 2017 | 06:54 PM
Air cleaner looks like the rite one for the cars application.....
Oil Breather cap looks like the rite one for the application....
The Carb on the other hand. You are rite. That one is for a later model car or truck the uses the emission charcoal canister.
You are correct in your assumption of the carb that belongs on the car would be a Carter/Ball&Ball....
Should look kind of like this or close too....
https://www.google.com/search?q=1967...TBq0a3g2yHgIM:
OR
https://www.google.com/search?q=1967...G_4nMfGDl_YaM:
Old May 16, 2017 | 12:27 AM
t65fury3's Avatar
OR
thanks for checking in again now i have a starting point at least will update as follows thanks again.
Old May 16, 2017 | 02:36 PM
No. Problem... You are welcome on the help side...
I have a carb (Cater Ball and Ball) but it's for a 1967 383 car...
Let me know if you need some pictures...
Old May 16, 2017 | 02:40 PM
t65fury3's Avatar
will do i talk to a local place called milford carb and the guy said the extra tube is a vent tube it runs into a black canister emission crap.how ever he said just get a vacuum cap for it see how it runs it should be ok
Old May 16, 2017 | 04:20 PM
Yep.... Kind of what I mentioned...
Some guys use a pair of vise grips and remove the tube...
Old May 16, 2017 | 04:58 PM
t65fury3's Avatar
got her washed today but had to use a machine soap of sorts the heavy coating of dirt was so bad nothing would clean it now i have to use a cleaner wax on her and an orbital waxer machine to help clean that soap off but for me this is the fun stuff so I'm happy so far.she will need an engine rebuild at some point because it does blow oil when you hit the gas but i would like to run it for the summer hoping this is the car for me to keep and enjoy.i like it so far the ride is comfy yet floaty my type
Old May 16, 2017 | 06:02 PM
Hear are a couple of suggestion....
For waxing and cleaning and restoring the paint....
http://www.z-bestcarwax.com/
And then for the engine and other products...
https://seafoamsales.com/
Try the engine oil supplement...
Also Lucas Fuel treatment....
https://lucasoil.com/products/fuel-t...fuel-treatment
Old Sep 16, 2017 | 10:59 PM
t65fury3's Avatar
so sorry i just checked my post history to be sure i am saying thank you for the advice got the carb in a while back its good just have to get the choke working right it starts fine but when i step on the gas it opens the choke up need to fix that but otherwise a good carb
Old Sep 17, 2017 | 01:45 PM
mikerp76
Apr 24, 2013 07:03 AM
SRT74
Jul 16, 2010 05:19 PM
deadkelly
Mar 29, 2010 05:02 PM
bigsho
Jul 7, 2009 04:59 PM
rubadub
Nov 20, 2007 11:04 AM
