rear end question
Old Aug 17, 2012 | 04:47 PM
red64valiant's Avatar
rear end question
I think my 64 valiant has a 9inch ford rear end in it. Does anyone no how to tell or if you have heard of this before what would it have came from. I think it must be about a 3.91 but haven't determind that for sure. Would like to change to a little more of a road gear. Thanks
Old Aug 18, 2012 | 03:01 AM
9" ford is similar to the 8 3/4 with a removable center section. Changing gears is simple Just swap center sections.
Has great aftermarket support
Old Aug 18, 2012 | 03:22 AM
Here is what most MOpar rear axles will look like. Doesn't mean that someone could have swapped it out for something else though.
Old Aug 18, 2012 | 08:53 PM
Thanks for the reply Cant seem to read numbers and letters or make much since of what i see. May just have to take it out this winter,and then figure it out. Thanks
Old Aug 19, 2012 | 05:42 AM
Take a coupld of pics (front and back) of it, post them up and we'll see if we can help ID it.
Old Sep 29, 2012 | 05:33 PM
Chryco Psycho's Avatar
if there are 5? bolts around the front pinion yolk where the driveshaft bolts on so you can remove the pinion then it is a Ford 8 or 9"
Old Sep 30, 2012 | 04:46 AM
They both had that 5 bolt pattern. I don't know enough about them tho to tell you how to ID them.
Old Sep 30, 2012 | 10:26 AM
Id'in Ferd 8, 9, 9+" rear ends
The quick way to tell a Ford 8 from a 9 IF you know it's a Ford, is to look at the bottom bolt below the pinion. An 8", you can access all the lower bolts with a socket/ extension. On 9" rears, there is one bolt which the pinion casting overhangs, and you MUST use a box/ open end wrench.
But the Ferds are MORE complicated by a larger Lincoln rear, which looks a lot like a 9", a 9 3/8, which according to "Kevinstang" is also appearing in some pickup trucks.
But I saw an axle for sale on Craigs the other night and I STILL do not know what it was. It was a 3rd member type, but was not Ford or Chrysler, nor AMC. Might have been 55-57 Chev, or the old Olds or Pontiac axle.
http://www.kevinstang.com/Ninecase.htm
http://www.fordification.com/tech/rearends_ford01.htm
I don't know if they will fit the early A's unmodified, but I have a completely stock Ferd 9" under my 67. It is out of a Lincoln Versaille, built on the Ferd Fairmont/ Merc Monarch platform. For a VERY few years, the Verailles used a 9" with disc brakes, and the spring perches are only about 1/2" wider total than the 67. It IS a tad wider which can be made up with wheel offset.
I would not do this again, that is, the Ferd disc brakes, as parts for them are difficult to come by. I may, if needed, rework it to use Jeep rear disc setup.
Old Oct 2, 2012 | 08:08 PM
red64valiant
Thanks for all the replys I am now sure it is not a mopar rear end. Just got it up on jack stand tonight will get pictures, and more info and try again. I am almost sure it is a ford. Just not sure what it is out of doesn't look to have been cut down.
69POLARA383
Feb 3, 2012 07:43 PM
THE GOOSE
Mar 10, 2011 02:59 AM
71mopar
Dec 12, 2009 07:44 PM
stanhope55
Mar 19, 2009 05:35 PM
72_coronet
Jan 12, 2009 05:57 PM
