Wheel Stud Problems - Too Short! Help!
Old May 23, 2014 | 07:57 PM
hckrphil's Avatar
Working along on my 1934 Dodge project with a Helix Suspension front end. Needless to say, Helix's tech support is useless if and when I ever hear back. I've called them twice, left them messages both times, and have received ZERO call backs.
Posted to their facebook page, only to be told to call (which I did). Then I posted again and they told me to email one of their techs (which I did) and his response to me about what Year / Make / Model car did they base their front studs off of was to "go to summit they should be able to help you".
See the attached photo. I have 1/2 - 20 lugs, .516" knurl, and 1.75" long.
Ideally I need lugs that are 2.5" long..... I can't find these with the correct knurl ANYWHERE.
Thanks!
~Phil
Attached Thumbnails Wheel Stud Problems - Too Short! Help!-knurl.jpg   Wheel Stud Problems - Too Short! Help!-length.jpg
Old May 23, 2014 | 08:42 PM
Boat Guy's Avatar
Do you have a part number and manufacturer for the Studs you have?
Old May 23, 2014 | 08:46 PM
hckrphil's Avatar
No, that is part of the problem. The only thing I have on the stud is on the head of it, its stamped "835-"
~Phil
Old May 23, 2014 | 09:01 PM
Is it too large or small. Find some and ream the Axel hole out to fit...
ARP 100-7703
long studs modify to fit !!!!!
Old May 23, 2014 | 09:48 PM
Boat Guy's Avatar
OK, I'm betting that is a Doorman 610-183 wheel stud. They list the specs as 1/2 - 20, .560 knurl, and 1 11/16 under head.
The closest what you asked for that I can find, is a Doorman 610-192. It isn't as long as you asked for. It is only 2 1/32 under head.
You could try the Doorman 610-073 which is 2 3/8 under head, but the knurling is longer. Any auto parts store should be able to grab one out of their doorman bin to let you compare them. Or cross reference them to their brand.
That is the smallest knurl size they offer on the 1/2 - 20. I would think if it was any stock application doorman would have a stud for it.
Old May 23, 2014 | 10:22 PM
I'm betting Non stock racing wheels. look at Summit ??? Maybe a screw in stud
Old May 24, 2014 | 05:13 AM
This is bringing back nightmares of putting late model Ram wheels on the '92 truck.
Searched the Dorman catalog to end up with slightly too large of knurl.
Had to pull the axles, sanding roll dremel each hole a bit and press in with the hydraulic press.
Looking back it really wasn't that big of a deal, the only other option was to tap each hole and install race screw ins at a larger size. That was too much hassle and work.
Old May 24, 2014 | 09:42 AM
hckrphil's Avatar
So if they list it as having a .560 knurl......... why do I show .516 when I use my gauge? Am I measuring it wrong?
~Phil
hckrphil's Avatar
The car came with STR rims..... pretty thick.
Old May 24, 2014 | 10:11 AM
Try Calling Pete & Jakes and see what they have to say...
http://www.peteandjakes.com/Catalog.aspx
I'm Sure they have run into it before...
Old May 24, 2014 | 11:03 AM
Boat Guy's Avatar
~Phil
No, you're not measuring it wrong. The hole for the knurl should be smaller than the knurl. What you mic'd on the outside edge of the knurl would need a hole about .509 to fit tight. There is a .509 knurl listed, which after an allowance for press fitting, would make the .516 about right, but they are all 12mm studs. I'm not sure if the listed knurl is the actual outside dimension or the hole size. Verify that the .509 knurl won't be too loose and that is the hole size.
Personally I would lean more towards going to the 12mm studs and match the fit. As an old parts guy, this kind of thing is fun to me. Let us know what you end up with.
Here is the ARP # for 12MM - 1.5 2.5" long with a .509 knurl : ARP #070-100-7708 Jegs and Summit both carry them.
Last edited by Boat Guy; May 24, 2014 at 11:22 AM. Reason: addressed size confusion issue
Old Apr 5, 2017 | 08:10 AM
Chris Linville's Avatar
I'm having this exact problem with helix. Did you ever find studs that worked?
Old Apr 9, 2017 | 02:23 PM
xtopfuel's Avatar
I would call Alston or chassis engineering
xvodysseusvx
Jun 25, 2018 04:38 PM
1966DartConvertible
Jul 20, 2011 10:10 PM
jar84203
Jul 29, 2009 03:22 PM
nesparky
May 26, 2009 07:37 AM
Duster703404
Nov 16, 2008 06:00 PM
