Wiring electric fuel pump
Old Feb 20, 2019 | 09:07 AM
f_armer's Avatar
I'm building a 1951 Fargo truck.
its on a 1988 Dakota chassis.
with a 400 and 727 auto.
I'm at the wiring stage and I have a couple different scenarios I need to run to get opinions.
I am using part of the dakota wiring harness and it had the coil + wire tied in with the fuel pump.
if I wire it like the second pic, when the engine is running the fuel pump will be powered through the ballast resistor?
am I over thinking this??lol
I'll post some truck pics in another post
Old Feb 20, 2019 | 09:19 AM
f_armer's Avatar
Some pics
of truck
Old Feb 20, 2019 | 03:53 PM
Looks like a great project, the only question I would have is why the oil pressure switch wired in, with today's gas I think I would want the fuel pump to run prior to the engine starting even with a tq.
Old Feb 21, 2019 | 06:32 AM
f_armer's Avatar
um thats the whole point of the oil psi switch, it gives the pump power while starting, then when it gets oil pressure it'll stay running, but if the engine dies the pump shuts off.
Old Feb 21, 2019 | 07:59 AM
I think we are missing the point, key on fuel pump on before start before crank. I understand about the oil pressure shut off just not a fan. That's what big red lights are for, and mechanical gage's for oil presser.
Old Feb 21, 2019 | 09:54 AM
f_armer's Avatar
using an oil pressure switch is the "approved" method from what I can tell. Google electric fuel pump wiring.
I am using a mechanical gauge for oil pressure
big red lights? They aren't going to help if your in an accident and the fuel pump continues to pump fuel onto a fire.
Old Feb 21, 2019 | 03:21 PM
Don't have accidents.
I've seen ignitions wired to oil pressure senders, what a pain everything depends on a six dollar part from china.
Old Feb 21, 2019 | 03:45 PM
f_armer's Avatar
Awesome advice Thanks!!
Old Feb 22, 2019 | 08:55 AM
I've been around fast cars for the last forty years and the only time I can think of your way would have been a good idea was when a friend stopped by another's and left his Camaro running, he stayed to long ran the car out of gas and ran the battery down. Kinda funny when I heard about it. You might run another switch to fill carb prior to starting, that will help if that's a cast iron intake and your using a fuel with alcohol in it. Today's fuel tends to percalate out of the carb.
Old Feb 22, 2019 | 03:55 PM
Why not just use a 2 pole switch and interrupt the relay?
Old Feb 22, 2019 | 06:31 PM
f_armer's Avatar
I got it figured out, i ended up adding another relay
Old Feb 22, 2019 | 06:51 PM
I think you had it rite....
https://www.bing.com/images/search?v...jaxhist=0&vt=0
Old Feb 23, 2019 | 08:38 AM
That Vega switch was a pain and caused grief, it would leave a guy sitting with a car that will not start. Even when it has oil pressure but a bad sender, this I have seen more than once and heard from others. I don't like the Vega sender setup.
Old Feb 23, 2019 | 10:25 AM
Iowan,,,,, Very true Statement... Not Arguing that fact...
I'm just helping with the question...
Old Feb 23, 2019 | 12:49 PM
Essentially that's what he is doing, using a Vega style sender to run the fuel pump, a better way is to do what the car manufacturers did a use a trip relay for a collision if that's what the concern is.
Illiana
Jun 25, 2018 05:02 PM
josehf34
Dec 15, 2013 04:52 PM
66belvkm
Nov 23, 2013 10:50 AM
D.j. Kellogg
19
Mar 10, 2013 04:17 AM
Rosfrei
Oct 3, 2009 08:49 AM
