440 Engine Swap
Old Feb 17, 2022 | 10:50 AM
jibs1723's Avatar
440 Engine Swap
Hi all I am putting a 1968 440 with an NP435 into a 1979 W400 that had a 360. I am replacing the NP203 with an NP205 transfer case and was using the stock truck motor mounts that came out of a 1977 D300. I just went to drop the motor in and it appears to be sitting too far back. Hard to tell as I have the cab off the truck for body work. Is anyone aware of either a different motor mount used in the 4wd big block trucks or transmission cross member? The cross member is from the small block truck. Thanks
Old Feb 17, 2022 | 03:34 PM
Lostviking's Avatar
Did you check online to see if the trucks used the same part number?
Old Feb 18, 2022 | 08:56 AM
Wow... I have no idea....
Looks like from that angle, that the mount needs to be mounted on the front block ear tabs!!! But i'm not sure if that would fit that way?
Can't say that i have see any mounts with that much offset....
87powerram
Sep 20, 2019 11:35 AM
mopsled
Feb 3, 2017 04:36 PM
dr_riedel
Mar 21, 2011 01:26 PM
Dave E
May 25, 2010 12:27 PM
dobaon22s
Nov 5, 2008 01:42 AM
