Electrical things in meltdown
Old Jun 20, 2019 | 01:04 AM
Deep Six's Avatar
Hi Guys
Got a problem with a pair of electrical units mounted on the drivers side inner fender on my 84 D150, going by the puddle of resin like goo running down and pooling underneath I'm guessing these are now toast.
But wondering what their function is (or was)
Old Jun 20, 2019 | 05:35 AM
I'm not 100% sure but..... From Left to right
1. Voltage Regulator
2. EGR Delay Controller
3. Starter Relay
Hope this helps...
Old Jun 20, 2019 | 08:00 PM
Deep Six's Avatar
Thanks Bob,
I did a little googling on the part numbers appearing on the outside casing but inconclusive
far left is 4111172, middle is 4111481
Old Jun 21, 2019 | 01:12 PM
https://www.google.com/url?sa=i&sour...61234162180835
Old Jun 22, 2019 | 08:02 AM
rbkt65's Avatar
the one on the left is egr timer, if it has red,grey, brown wire w/orange tracer. right one is air switching timer if it has red,dark green and brown wire w/orange tracer. air switching is for units with air pump. yours may have already been removed though. almost every timer or module mopar has ever had has melted the stuff out of the back. it was put there to keep vibrations down. look at some ignition modules. they will still run even after "insulation" is gone. this was taken fron 1984 service manual wiring in ignition section. hope this helps.
Old Jun 22, 2019 | 04:52 PM
Deep Six's Avatar
Thanks RBKT
I think both those modules are obsolete, pretty sure the air pump is long gone, and the truck has an edelbrock manifold so assuming EGR is no longer operational, at least not the timer regulated original system.
Monty.Smith
Feb 23, 2022 04:50 PM
Rich Markiewicz
Dec 30, 2018 04:27 PM
hkestes
Sep 7, 2018 08:51 PM
Wolffwreck
May 26, 2018 02:01 PM
gwsharklover23
Apr 18, 2018 12:55 PM
