71 Charger rebuild
Old May 1, 2013 | 04:53 PM
  #91
Gorts 5th's Avatar
Smile
well its a labor of love... what does your brother know, i bet your wife is jealous.
Old May 1, 2013 | 06:39 PM
  #92
jacilynn_s's Avatar
First thing, frame connectors are a must, not putting them in is foolish and waiting for bad fitting doors and window leaks.
I have NO clue what the hell you are talking about. I've done hundreds of cars and have never had a problem with doors or windows leaks. Since these are all driven cars including drag racing cars that I see often I can honestly say you are way way off base with that comment.
The only window leaks I have seen are from shot weatherstrips or windshield leaks from bad installs at other shops. Door hinges wear out and need to be rebuilt which has absolutely zero to do with the body of the car.
Sorry for the rant but stuff like that which has no basis in truth just ticks me off to no end.
Old May 1, 2013 | 06:57 PM
  #93
No basis? OK, thanks for coming out. I'm sure everyone enjoys you sharing your opinion on how they should build their car.
Old May 2, 2013 | 05:32 PM
  #94
Buffalojoe426's Avatar
Yes it is a labor of love, helps not having a wife to be jealous! "You spend too much time with that car and not enough with me!"
My brother has a degree in electrical engineering. As for now he helps with the manual labor. But I shall put him in charge of helping wire the car.
Old May 2, 2013 | 05:35 PM
  #95
Gorts 5th's Avatar
Smile
he'll do you good.
you ouat to install L.E.D. light boards for you makers, cool XF
Old May 5, 2013 | 12:40 PM
  #96
Here we go!
Coronet 500 suggested cutting the flange on the K member. Sounded like a solid Idea so...
I also got in a shipment from summit
Got the K member primed up.
Then a shipment form Rock Auto arrived!
Painted up the new lower ball joints.
And the K member.
Cutting the flange freed up quite a bit of room.
Old May 5, 2013 | 12:41 PM
  #97
My brother arrived in, I put him on the blast cabinet cleaning parts and bolts.
I decided to take a tap and clean out the threads on everything we worked on.
Then I let him torque it on down.
We left off here to go see the new Iron man Movie.
I blasted and painted the rear shackles.
Now its a waiting game for the parts I took to the blasters to get back.
Old May 5, 2013 | 03:42 PM
  #98
jacilynn_s's Avatar
saw the movie wasnt that bad IF you go buy the movies alone anyways.
You didn't have to cut that much off usually its only on the passengers side that you should trim it a little for oil pans to clear with 3/4 in.
Old May 16, 2013 | 08:42 PM
  #99
Haven't done much more than piddling around lately.
Disk break brackets for the front.
My dad bought some new media for the blast cabinet. This stuff works great!!!! It cuts fast and doesn't make much dust. I can even blast with out setting up the vacuum.
The door hing rebuild kit arrived today.
With a little bit of drilling and grinding I got everything together with no play.
I didn't take any pictures of the old pins, however they were worn pretty bad.
I have been blasting a few small parts here and there.
I went by the blasters today to check on the parts. They had half of them done. Should be ready by the begging of next week. I also pulled a set of wheels out of storage to set the car on while working the body. Some times it pays to store crap from other projects. The last thing I got on was pulling the axle shafts down and knocking out the bad studs. Got the face of one cleaned up and primed. Need to go to Napa and get some goodies to put it all together.
Old May 22, 2013 | 01:34 PM
  #100
Three days straight, non stop.
Got all of the parts back from the blasters.
Changed out the bushings in the springs.
And started lining everything up under the car.
Put it back together and started letting it down.
New bearings for the front and back.
Touch down on the rear.
Old May 22, 2013 | 01:40 PM
  #101
Working on the front.
Back on four wheels again!
A little touch up work on the passenger door.
Ready to mount!
Now you see the braces....
now you don't
Old May 22, 2013 | 01:43 PM
  #102
Passenger door mounted.
Driver door
Put a coat of pain on the rotisserie to keep it rust free until I need it again.
Old May 24, 2013 | 02:53 PM
  #103
FERAL's Avatar
Wow!
That's alot of work!
Old May 25, 2013 | 05:42 AM
  #104
Gorts 5th's Avatar
Smile
I noticed you installed poly bushings how hard was it to install them any issues?
Old May 25, 2013 | 04:54 PM
  #105
The hardest thing was removing the old rubber ones. At the front of the spring there is a metal OD ring that needed to be removed. I tried to drive it out with the air chisel but it just bent down the edges. So I used that to press it out with the jack press. The front lower control arms also required the use of a press to push out the shafts and push them back in. Oh and the sleeves on the upper control arms were not fun either. All in all not to bad.
Old Jun 2, 2013 | 08:46 PM
  #106
For $400 I got what you see here plus a crank and rods. 1 440 block with heads + 2 727s, 1 manual transmission and a sure-grip rear end.
Old Jun 18, 2013 | 04:28 PM
  #107
maynardc69's Avatar
Got one hell of a deal there. Sure grip alone is worth that. I'm buying a 71 charger se with a 383 soon and I may be back to look at your pics. Thanks for the updates!!!
Old Jun 19, 2013 | 08:48 AM
  #108
Between work and vacation there hasn't been much time to do more than piddle.
There was a piece of rubber on these strikers. Its gone now and I don't want to pay $20 apiece for new ones.
And we have some dent pulling!
Old Jun 19, 2013 | 04:16 PM
  #109
Here's one for ya Joe:
Old Jun 20, 2013 | 06:51 PM
  #110
Wow, That's a mans man right there! He is a bad *** in my book just for riding a buffalo! But punching a cougar?!? That's tough. I laughed my self near to death!
The closest I ever come to riding one was standing on its head when it got caught in the gate. And it wasn't a 2,500 lb bull like that either!
Old Jun 20, 2013 | 07:26 PM
  #111
Ok time to get serious!
Lets keep those dents coming out!
Trunk Lid!
Needs a little work.
Front right fender looks like hell.
Take everything out of the way.
Cut out the bad.
This should make a nice patch.
Cut it and bend it.
Fit it.
Bend it some more.
Fit it, mark it up, and clamp it in place.Name:  DodgeCharger439_zpsea2a6724.jpg
And this is as far as I got today.
Old Jun 23, 2013 | 05:35 PM
  #112
Lets start where we left off!
Really don't have a better place to hang it to knock out the dents.
But man does it look good on the side of the car!
Back to welding!
And for this piece.
A little pin hole welding and priming!
More to follow soon!
Old Jun 25, 2013 | 08:12 PM
  #113
Third installment fender restoration!
Get a friend to help!
Take pictures!
I love getting parts delivered! Its like Christmas, or my birthday!
My friend Matt working on a patch piece.
He is not as fast as me, but two hands are faster than one.
Ill handle the welding, you can make another patch!
As I was welding my friend was wire brushing another section. I look up to see that the grinder has stopped working. This is a serious problem because the grinder is my DAD'S oldest and favorite grinder!
All work must stop until it is fixed.
turns out one of the wires going to the switch broke off.
So I cleaned up the wires, cut a new section and fixed it!
Back to the jobs at hand!
We started on a few more patches and then called it a day!
Ill get back on it tomorrow and hope to have this fender fished by Thursday!
Old Jun 28, 2013 | 08:28 AM
  #114
Ok so its Friday and the fender is not close to finished! God this takes a lot of time!
here is where I'm at.
So I messed up on this one the other day. Nice thing about metal, cut it and re weld it.
I got called into court Thursday so all of this happened Wednesday. I'm hoping I can get this wrapped up this weekend before Work starts back Monday night.
Old Jun 28, 2013 | 09:43 AM
  #115
You are doing an awesome job Joe! Keep it up!
Old Jun 30, 2013 | 02:50 PM
  #116
End of a week.
Primed up the finished pieces.
Fit it and clamp it into place.
Got some use out of my spot welder.
A lot of use out of it.
The front of the car had to be hammered back into place for the fender to fit.
Old Jun 30, 2013 | 02:56 PM
  #117
On to the other fender.
Had to knock up a sketch and measurements for the brace.
This should work for a replacement brace.
Got the bends!
Cut lines.
Start bringing out the sides.
And that's where I stopped I will get back on it next weekend.
Old Jul 16, 2013 | 06:31 PM
  #118
Some work on fenders.
I hope to have this one done tomorrow!
Old Jul 17, 2013 | 07:39 PM
  #119
Finishing up the left fender.
Just a loose fit on the car.
Old Jul 18, 2013 | 10:00 AM
  #120
Wow...Looking Good...
