Inner wheel seal with dust lip -orientation?
Old Nov 16, 2019 | 06:08 PM
74MAX360's Avatar
These inner wheel seals have a large dust lip on them. Does it go on the outside? The sealing lip with the smallest id points the other way -so I would assume that it points inward?.
PIC ATTACHED
Old Nov 17, 2019 | 04:38 AM
Goes in the hub. Seat side outward..
Old Nov 17, 2019 | 06:49 AM
74MAX360's Avatar
So the seat side (I assume you mean the side with the flat metal part) which should be outward has the dust lip sticking way out and I have to find something that fits around that -but still contacts the edge of the metal to install it?
The other side has no flat metal part, just a metal edge/rim.
I got confused by all the shade tree mechanics on youtube hammering seals in with a piece of wood -which would not be possible with that dust lip.
Old Nov 18, 2019 | 02:01 PM
I could not find a photo with a quick search that i did... The point of the extended lip it to reach farther towards the backing plate and cover the spindle complete. That is why the large lip goes to the outside of the hub. I use a pipe to drive mine in... You dont have to use that seal. But I use them when I get them.
Old Nov 18, 2019 | 04:21 PM
74MAX360's Avatar
Thanks! I really appreciate the help!
Old Nov 19, 2019 | 05:41 AM
No sweat.... Post up a picture when you get it installed if you get time...
Old Nov 20, 2019 | 06:45 PM
74MAX360's Avatar
Should have some pics to post soon. Meanwhile.... I replaced the steering pump and steering gear -and i know I have to bleed the system -but there was a paper in with the steering gear that said something about setting "poppets" -but only on some steering gears -so I'm not sure if I even have poppets in the steering gear or what. Ever heard of this?
Old Nov 21, 2019 | 08:02 AM
Not that I can recall....
dodgem880
Jul 8, 2018 05:55 PM
dodgem880
Aug 22, 2017 07:45 PM
t65fury3
May 14, 2017 02:48 PM
98 SNAKE EATER
Mar 22, 2013 03:37 PM
DodgeRamFan23
Apr 9, 2011 07:33 PM
